Scooby
Hello, all.
My sis-in-law has been without broadband for weeks now. Home telephone works fine. Her line rental is with BT and her ADSL broadband with Virgin.
I've been trying to help her out by going on the Virgin 'help' forum, as to phone Virgin is a worse experience than sticking pins in your eyes.
Helpful person on the Virgin forum has carried out line tests and reports there is definitely a fault - they say to get on to BT to sort it. Hey-ho, BT says there isn't a fault. Virgin asked my sis to ask BT to carry out an "enhanced copper continuity test". BT says "Have done, the light is green - there is no fault".
I think it's called stalemate.
Ok, Virgin have at least provided some test results, and when I asked my sis to compare these with BT's, the BT lady said "There's no figures - just the light is green - there's no fault..."
Sis suspects that BT basically don't give a t*** because the broadband is not with them, only the land-line phone - and that works ok.
So that we can knobble BT if they are being deliberately awkward, could anyone give the answers to:
1) Should BT's 'enhanced copper continuity test' return results with more detail than "the light is green..."?!
2) Do any of Virgin's test figures (below) mean anything to peeps on here? If so, which ones suggest a problem? And could this 'problem' be as serious as to mean that my sis has broadband sooo slow that it takes - literally - 2 hours to load one eighth of a Google homepage...?
Many thanks!
Test Result Attribute | Value |
Line Test Ran Successfully | NO |
Test Result | Line tested OK. Measurements within specifications. |
Line Length | 3847.6 Meters |
Capacitive Balance | 94.0 % |
A To B Resistance | 1633.724 ohms |
A End BatteryResistance | 9999.0 ohms |
B End Battery Resistance | 9999.0 ohms |
A End Earth Resistance | 9999.0 ohms |
B End Earth Resistance | 2250.079 ohms |
Additional Info1 | CAPACITIVE BALANCE POOR 94 % |
Additional Info2 | TONE RINGER DETECTED |
Many thanks!
