E.E.I
Not sure if this is in the correct section
Hopefully someone can help me with this one
So recently rewired a house and included was some additional telephone points. All cables installed correctly away from mains cables
The telephone points are wired in cat 5e
There are two slave points and one master point, the master point uses the BT nte5 outlet.
The slave units are wired individually not in series
All points ring out when a phone is plugged in. The trouble I'm having is once the broadband router is plugged in via the ADSL filter, if you then pick up the phone and listen to the dial tone you can hear what sounds like the old Internet dial up tone, it is faint though.
The other trouble I'm having is once these slave units are connected, the broadband speed reduces by 1Mb, this is a major problem because the property only gets 2.5Mb Max.
With the two slave units disconnected the broadband hits the 2.5 Mb and with the phone plugged into the master point (also via the ADSL filter) there is no dial up tone.
I have connect each slave circuit individually to see if it was a fault on one of them, but I get the same situation.
any one ever had this situation before?
Sorry it's a long post
