Telephone point and Comms cab | on ElectriciansForums
Discuss Telephone point and Comms cab in the UK Electrical Forum area at ElectriciansForums.net
Nottingham, UK
I have an office with a comms cabinet with Cat6 cable running around the building. Will I be able to connect a landline at the points where there is a Cat6 or would this have to be a separate cable/install
https://cpc.farnell.com/pro-signal/...MImZuVkfi-7QIVT_BRCh2Z5Q2eEAQYAiABEgKxLPD_BwE
you will need to wire phone line (after master socket) to a spare rj45 socket in the coms rack
patch from there to the outlet you want the phone plugged in
then use line adapter listed above
So I've just been instructed by the client to upgrade from cat 5 to cat 6. The client arranged for BT to come and do their bit which has been done. I have then just ran cat 6 to the points the client asked for, will the clients IT guy be able to sort it from this? Im thinking from what you have said they should be fine?
Reply to Telephone point and Comms cab in the UK Electrical Forum area at ElectriciansForums.net
Nail as a fuse works until it doesn't. When you say certain areas what does that mean? If you have been doing it like this for 4 years why the...
Yes, you run each socket as a point to point connection, and use a switch (it doesn't need to be PoE unless you are wanting to power devices via...
