Telephone points. | on ElectriciansForums
Discuss Telephone points. in the Australia area at ElectriciansForums.net
hoppy
Liverpool
Hi guys need some help with telephone points.
I currently have 1 main point for the phone, which i have an extension plugged in to connect to the alarm.
I need 3 more points for sky tv, what is the best way to wire these, i am an electrician, but have never had an experience with phone lines.
All help and advice appreciated
thanks
Craig
Loads of ways to wire telephone points. Depending on the runs you can just loop the extra points starting from your main one. Or wire two back seperately to the main one, or put a joint box in somewhere...
[ElectriciansForums.net] Telephone points.
With modern phones the connection to terminal 3 (ringer circuit) is not needed and if used could cause interference on an ADSL (broadband) line causing poor internet speed, BT produce a product called an I Plate that disconnects terminal 3 to stop interference, If the line is an ADSL line don't forget you will need microfilters plugged into each socket.
Reply to Telephone points. in the Australia area at ElectriciansForums.net
M
Aqualisa electric shower, mains water entry point blanking plug Hello, Im looking for help in tracking down a replacement part for an Aqualisa...
Marty
M
well now to throw some stuff on the tv wiring I did ages ago I have a labgear 8 port distribution amplifier mounted in the airing cupboard...
