telephone wiring | on ElectriciansForums
Discuss telephone wiring in the UK Electrical Forum area at ElectriciansForums.net
smiffy911
Hello all,
As part of a large rewire I have to wire in 6 telephone slaves.
I have neve installed this many points before.
Am I ok just wiring from the master socket out to the first slave then onto next in parallel, then next etc etc.
Or would it be better to wire 3 from master, and the other 3 also from master.
Thanks for your replies.
Depends how much you need and what you have lying around, Cat5e is cheap enough if you are using it alot. As you will be wiring this to the telephone points , it doesn't work for home networking, for that you need another cat5e wired back to a central point like where the router is going to be. Or you could just use wireless.
Reply to telephone wiring in the UK Electrical Forum area at ElectriciansForums.net
Hello What was the conclusion of your problem?
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
