Tell me if this is going to be an issue | Page 2 | on ElectriciansForums
Discuss Tell me if this is going to be an issue in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Don’t bite my head off, I’m not used to installing radial circuits. Just the odd spur, or an rfc if new circuit.
Between being Sunday, man flu and an early alarm... my brain has stalled.
A while ago I ran a spur from 32A rfc direct from the mcb to supply a new double socket in my hall. Only gets used by Henry... or the new guy: Dyson.
What I am wanting to do is make a utility room with washing machine and tumble dryer, and maybe another double socket. Easiest plan is to use that spur from earlier, put it on its own 16 or 20A mcb and make a radial with hall socket on the end.
Question is, are radial circuits ok for a couple of high power appliances and possibly dyson on all at the same time, or would I be better installing a 32A ring for just these 4 points?
In the US the tumble dryer requires a 30 amp service at 240vac, washing machine requires a 20 amp 120vac isolated circuit. I don’t know how y’all do it or the current on the dryers and washing machine in the UK
our machines are only 10A each so generally plug into the socket circuit. in OP's case, it's a combined washer/dryer,so it'sphysically impossible to have both parts working simultaneously. it washes then spins, then tumble dries in sequence. don't forget, all our appliances are 240V so 1/2 the current you's need at 120V.
No sure of my load of our washer dryer, apologies I meant washer dryer in my previous post, but it runs off our 13amp sockets. It has an ++A efficiency rating, so shouldn’t be using the fall amount.
I think your appliances are a bit bigger than ours, if I understand it correctly you normally have them somewhere other than a kitchen?
Our standard washing machines or dryers are often in the kitchen and designed to fit into a standardised kitchen unit size. Usually this is a 600mm(~2') wide space. Consequently they require less power to operate as they wash or dry smaller amounts of clothes each time.
Dave your right there so big we have a laundry room and that dryer eats up some power
Bigger houses or more modern ones will usually have a seperate room, usually referred to as a utility room, but for the 'average' house these appliances are in the kitchen.
We also have the washer/dryer which combines both functions in a single machine, which I doubt is so common for you?
Not really I didn’t know they made them to wash and dry in the same machine
Reply to Tell me if this is going to be an issue in the UK Electrical Forum area at ElectriciansForums.net
Why aren't you asking them?
Sure, I'm on the Isle of Sheppey. also the cable they used I think was 2.5 twin and earth, although I could be wrong.
