C
coxy84
hi guys!
iv been asked to install a temp supply for a very small festival, and issue a cert, there will be 2x 20kva gennys supplied,
there will be a couple of marquees/ stages,
i havent done much of this kind of stuff before, so any tips or things i should look out for would be useful.
also would a normal eic cert do the trick.
Make sure you have a copy of bs7671 at hand as this falls under special locations, haven't done much in this line of work myself however and its too late at night to go rummaging for books but wil take a flick through tomorrow if I get the chance
cheers iv been looking at section 711, i assume i need to bond the stage's ect do these need to be taken back to the met or can they have there own spike? im going to use 30ma rcds to cover pretty much every thing.
temp electrical installation
Australia
coxy84,
coxy84,
