Temp supply cert question | on ElectriciansForums
Discuss Temp supply cert question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
Arv
Hi all
Its required we need to install a temp supply for 4-6 weeks in a property, (for the contractors) then its completely removed.
we take supply from the CU and run 2-32a circuits via rcd, disconnecting the original supply to property.
I dont have insp & Test qualification and im not NIC, but im happy to test myself & log my results.
The question is this..
Can this be done via minor works cert or have i got to get a multi page full report done?
Many Thanks for any help
Mark cheers for your reply.
the reason for this post was, we had a visit at the job from BG engineer who inspected the boiler & turned our supply of (from isolator) because it didn't have a cert?
Is he throwing his weight around being a jobsworth.
I would say that if the temporary supply is for the use of other contractors then it needs to be certified with an EIC.
Reply to Temp supply cert question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the mind of someone lying there wide awake at 3AM, just about anything.
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
