Temperature Indicators on Transformers | on ElectriciansForums
Discuss Temperature Indicators on Transformers in the UK Electrical Forum area at ElectriciansForums.net
M
Mustafa Mohd.
Hey Everyone,
Suppose we say the 'Temperature for Alarm is at 90 Degrees C' and the 'Winding Temperature Alarm is at 103 Degrees' on Transformers,
At what point of the transformer are we actually getting these readings from. I see RTD's connected to the top of the main tank from the outside providing indication in the Local Control Panel. But where are these RTD's actually connected on the inside? Are they even RTD's?
Thank You!
Reply to Temperature Indicators on Transformers in the UK Electrical Forum area at ElectriciansForums.net
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
