I'm in the process of renovating a house. As I go through room by room I am removing old plaster and as the cables are exposed at this point I figured I may as well get the wiring updated as I go. The ring main (~6 sockets) is currently fed from 2.5mm T+ E. Eventually I would like to have the whole house in 4mm radial though I can't do this all in one go.
Is there anything wrong with the proposal below which would allow me to replace the ring with a radial when I get round to that room and add a socket in the process?
Basically the 4mm would be connected to the start and end of the circuit (i.e. lollypop/hybrid) within the back box of the socket until the electrician gets round to replacing all with 4mm radial.
I will of course be getting a spark to do notifiable work. Circuit is protected by 32A fuse and is clipped direct
