Cajun_Country
I am trying to set up a temp power pole for new construction home. I have everything pretty much laid out, but started questioning the connection from the meter to the load center. I have a 125 amp meter socket and a 70 amp square d main lug load center with 20amp breaker to power gfci receptacle. My 70 amp panel will only accept #3 wire. With 1/0 wire feeding into meter, can I use #3 coming out into the load center? Thank you for taking time to help.
