P
Piratepete
Domestic - Hob isolator beside Oven isolator, both 32Amp supplies. SWMBO got a shock off the hob isolator when cleaning it with a damp cloth. Investigated - there's a break in the earth circuit between the switch and CU. The reason it's live is probably that the hob is electronic and has suppressors connected to earth.
The client is horrified at the idea of pulling up a new carpet, floor boards etc to sort this out at this time so I suggested a temporary fix of an earth link to the adjacent oven isolator. Would you do it? If so should a covering letter be sent?
Pete
Pete
