Temporary supply help | on ElectriciansForums
Discuss Temporary supply help in the UK Electrical Forum area at ElectriciansForums.net
Doomed
Dorset
I have a lockable outdoor cabinet with a 5 pin 63A 3 phase socket and relevant mcb and RCD in enclosure.
There is a bit of spare room in the cabinet, but not any room to mount a permanent fixture too.
I need a temporary supply of 3 x 32A and 3 x 16A single phase supplies for the weekend only, and possibly for one or 2 other weekends a year.
Suggestions for the most practical and cheap way of achieving this.
Its for a charitable thingy and I have offered my time for free, they will pay for the materials but don't want to spend too much.
I doubt that their power usage will be as high as 3x32 and 3x16 but that is what they have asked for if possible.
Tbh, rent a rubber box distro. Where in the UK are you? I can point you in the right direction.
OK, I'll PM you some numbers in the morning.
Reply to Temporary supply help in the UK Electrical Forum area at ElectriciansForums.net
Stick the socket in a large plastic wall box with hinge and padlock. Give customer letter with key...
4K
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
