Temporary workaround - power to garage | on ElectriciansForums
Discuss Temporary workaround - power to garage in the UK Electrical Forum area at ElectriciansForums.net
Raggy
UK
Hi guys,
I need to run power to my garage. At the moment, I've gotten away with wiring a long extension cable. 13A Plug on one end, cabled to double female receptacles at the other end.
So far that's worked fine as I've only used a LED light and some other low powered items. I just unplug from the house when I'm finished, roll up the cable and leave it in the garage for next time. Got nowhere near 13A.
I now need much more power available in the garage for heaters, tools etc.
I have a medium term plan for this - my back garden is going to be dug up later in the year and I'll be calling in a pro to run SWA from the mains, under the new garden surface and into a consumer unit in the garage.
My question is this - is there an easy way for me to temporarily run more power to my garage, in a similar fashion to what I'm currently doing? One piece of equipment will be drawing over 15A alone.
Any advice would be great. Thanks.
Cancel all TV this weekend and get the shovel out now and dig a deep trench. Deep enough so you won`t disturb it when you do your garden. Get your electrician in and then get your trench backfilled. Job done. If you can`t do the digging yourself, then find a local labourer to do the donkey work for you.
Do your neighbours like you?
If you do this, they won't. Especially if you buy one of those cheap, open frame jobbies from a DIY shed.
true, but the bonus is it may drown the sounds of the neighbour's squealing bratts as they fart around in the garden. we had that for a year till the sods were repossessed, 4 screaming female under 11's with a trampoline. had to turn up Pink Floyd and AC/DC on the hi=fi to drown the buggers out.
Reply to Temporary workaround - power to garage in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
