Terminal Box Wiring Coming Through Wall for Conduit | Page 3 | on ElectriciansForums
Discuss Terminal Box Wiring Coming Through Wall for Conduit in the UK Electrical Forum area at ElectriciansForums.net
h901
London
hi
is there a steel terminal box that caters for wires coming from inside to outside, all the terminal boxes i've found don't have holes at the back. i was just wondering what would be the correct way to feed a wire through the wall into a terminal box (then through conduit to a camera outside) do i just drill a hole through the box?
hope it makes sense
thanks
A 22mm bit is the standard tool for 20mm conduit. Slight wanderings of the drill bit will make putting 20mm tube through a 20mm hole a right pain.
As my bit boxes are currently in the house I just popped and did some measuring for you:
Galv box spout O/D - 25mm
Galv coupler O/D - 22mm
Brass bush O/D - 25mm (at widest)
Hope this helps
Hope this helps
You're a legend, I appreciate the help. Cheers
Based on the above would it be wise to get a 22mm long bit for the conduit and then a 25mm (or 26mm) to make space and the openings for the spouts?
That's what I do, piloted with a 10mm to start. I like the idea of a small core drill though I must say.....
If you will be buying the 25mm just for the end couple of inches, you may find it cheaper just to get creative with a small chisel, unless you need a 25mm bit for the future.
Just resurrecting this thread as I have a similar question and thought it'd be better to do it this way instead of starting a new thread.
As suggested by others on here, I've been using the box with the rear spout and it's worked well. But I've got a job that needs around 10 wires all to enter the same point (each wire is 6mm). If I use the above method that would mean 5 boxes with rear spouts and for some reason it doesn't seem the right way. Any ideas or help is much appreciated. Thanks in advance
Use larger conduit, up to 2" conduit and fitting are available here. no rear spout boxes, so drill the back of a box and fit a bush and coupler. Though finding the conduit tools might be harder, I have a stock, dies and a bender that will do up to 2", but they are not common items any more.
Wowza, nice set of kit. Thanks for your help
Reply to Terminal Box Wiring Coming Through Wall for Conduit in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
It possibly be a sheet rock screw. The NEC requires all holes cut in the studs should be no less then 1 1/4 inches from the studs and if any...
