Terminal Box Wiring Coming Through Wall for Conduit | Page 2 | on ElectriciansForums
Discuss Terminal Box Wiring Coming Through Wall for Conduit in the UK Electrical Forum area at ElectriciansForums.net
h901
London
hi
is there a steel terminal box that caters for wires coming from inside to outside, all the terminal boxes i've found don't have holes at the back. i was just wondering what would be the correct way to feed a wire through the wall into a terminal box (then through conduit to a camera outside) do i just drill a hole through the box?
hope it makes sense
thanks
What is normally done in this situation, is two boxes with 20mm holes drilled in the back, then a short length of conduit between the wall connected to the boxes with couplers and bushes.
Using boxes with the rear entry spouts would be more robust, and probably provide a better seal against the ingress of moisture.
Yes, an SDS drill will easily drill a 20mm hole in brick or blockwork. Won't even need an SDS one if it's blocks and soft brick! Daz
Cheers guys, need to buy a 20mm drill bit now ;)
As Andy78 says, you may find that you won't get a 20mm conduit through a hole drilled with a 20mm bit without a struggle. I think the reason is that the tip is usually slightly bigger than the rest of the drill, so the hole can wander or curve. I keep a cheap 22mm bit to poke through in those cases where the conduit is tight.
To avoid blowing the face off bricks, which can happen even with a small diameter SDS drill bit, I've started using a 22mm diamond core bit for some walls. Works quite well and is guaranteed not to damage the wall.
Good advice. So would it better to buy 20mm for main use but as you said a cheap 22mm just in case I need it. Or should I just get a 22mm (I don't want the hole to be too big though)
The diamond core drill bit is that used to internal wall or external (or both) - (sorry never needed to use one before)
It was just how it worked out for me. I already had the 20mm. 22mm is guaranteed to be big enough. Not really a problem unless you're trying to put some fixings really close to the hole perhaps. If anyone knows where I can buy a 21mm, I recon that would be purfect.
Both.
You need to use a pretty high drill speed to make reasonable progress as it's such a small drill diameter for a core bit.
Both.
Cheers
Oh ok, what drill do you use the diamond core drill bit with?
Reply to Terminal Box Wiring Coming Through Wall for Conduit in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
It possibly be a sheet rock screw. The NEC requires all holes cut in the studs should be no less then 1 1/4 inches from the studs and if any...
