B
Big_Nige
Hi guys :)
Can someone identify the terminals in the photos below, are they DIN?
I want to replace a set of LNE terminals in this row with a set with larger capacity. Any ideas where I can get some?
Hey Nige.
All these connectors are different but they have the same din rail mounting. Do your new ones need to have the same wire terminals or just the rail clips??
Wire Connection*:*DIN Rail Mount Connectors
Ideally I'd like them to be identical, so I guess I'll have to find out who made them. At least now I know what to ask for, thanks.
Mike: they are just terminal blocks, which happen to hang on a DIN rail (as found inside a Consumer Unit). Essentially just chocolate blocks, but with better identification and mounting.
Hey Mike.
Like Nige said we use them because they are better than normal connectors. I use them a lot on commercial heating jobs where those small domestic central heating J/B's just arent big enough.
It's a lot safer/neater than having a load of normal connectors floating round in a poly box.
Any ideas who this is made by?
Hi Nige,
Hope I'm not about to teach you to suck eggs :obut here goes anyway;...
Unfortunately i don't recognise these by sight, Various terminal manufacturers include; Weidmuller, Wago, Pheonix, contactum etc it depends on who your wholesaler stocks, the sizes refer to the maximum cable csa(so2.5 terms can take a maximum of 2.5mm2. If you replace these terminals for larger capacity they are likely to be wider & therefore take more space up on the rail ~ you could end up having to replace the rail also. DIN rail refers to different types & sizes of rail; the particular type that your terminals are mounted on is TS35 or "top-hat"
If you do replace the terminals don't get the blue ones because control industry standard denote these as being for I.S. equipment (Barriers etc), also make sure that you get the appropriate end [plates & end stops.
Sorry again if you knew all this; hey you could always send you're Grandma round I'll teach her a thing or two:rolleyes: .................... And not in a little britain way!!!:eek:
Regards Gaz..
Now that I didn't know, thank you.
The reason I want to know who made them, is that I need to replace just one on the rail.
I could probably find another make that would fit, but I'm way too obsessive for that :eek:
Either wiedmuller or klippon terminals.
They look like 2.5 terminals.
Just tell who ever your ordering them from is that they are for top hat din rail and you want an end piece.
Not obsessive just conciencious:D
Have you tried removing (temporarily) one of the earth terminals, as they are usually/generally double sided it may have the manufacturer on t'outher side.
Same thing, & I doubt it as they would say so
The 2.5N gives the game away:D
This is the best photo I could get:
I could do a higher-res image of any part of it if that would help. The bit at the bottom could be a manufacturer, but I can't read it, even after playing with Photoshop:
Hmmm Could be phoenix but too fuzzy to tell.
Bingo! I was trying to read it as a single word, now I see there is a logo, see below:
I should have guessed it would be Phoenix Contacts, as the end brackets are made by them (although a different shape) - these are the Clipfix 35 range:
Now all I have to do is find out which range these are from.
Firstly welcome along, the look like Weidmuller terminals to me guess im about 50% confident. I have some terminal books here ill try and find out for sure :)
Now i look a pratt didn't read all the posts did I sorry guys
I've found out what type they are, but to get a larger size cable entry, the modules are larger. Not sure I want to do that, so I could add a couple more and redistribute the cables: one set have 5 x 1.5mm flex in them! (not shown in these photos). Then I run out of room on the rail, so do they have to have the end backets?
You can get different types that are same physical footprint, have you got the dimensions you want to be close to? :)
Not the best of practices but If the earth terminals clamp to the rail using a centre screw then they can act as end stops, from memory some phoenix et's grip the rail with a spring type action so will restrict movement.
Why is life so complicated! I've found the items I want (see below), but now I can't find anywhere that will sell them singly.
Any suggestions?
Phoenix Contact
1 x 3003347 UK 2,5 N
1 x 3003350 UK 2,5 N BU
2 x 0441119 USLKG 2,5 N
Any suggestions?
Phoenix Contact
I have made a phone call waiting on result ill let you know when i do :)
Terminal Identification
Australia
Big_Nige,
Andy Smith,
