sparky147
Hi all, looking to install a jacuzzi for a friend of mine, but his fuse board doesnt have any room left, so was thinking of cutting into the main cable leading to the fuse box with a henley block, then running a 10mm cable to a 63amp rcd, question is what type of cable should i use? as terminating into the henley block will leave the cables sleeving exsposed. Any help will be great thanks
