Terminating T+E correctly | on ElectriciansForums
Discuss Terminating T+E correctly in the Australia area at ElectriciansForums.net
N
neuromancery2k
Sorry for the simple question but I'm currently learning....When, for example, I'm removing a light fitting and I want to terminate the T+E feeding it should I be terminating the conductors with line taps?
When connected a joint or terminating an end of cable I would use a juction box.
The box must conceal all live parts completely.
So a connector block is not sufficient in itself.
I'm not sure what you mean as line tabs
Reply to Terminating T+E correctly in the Australia area at ElectriciansForums.net
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
There is no homework, and I'll never see these photo again.
