- Joined
- Aug 11, 2007
- Messages
- 169
- Reaction score
- 27
Hi, What is the correct terminology for the plastic block with service fuse that feeds the meter ?
I have just looked at a job where the lead sleeved 2 core feed comes out from under the floor into a very old cast iron box. This is shaped vaguely like an upside down torso ! it has ceramic shields protecting the 16mm tails going to the meter. There is an earth clamp on the lead with an un sleeved earth running to one of the DB’s. It also has a bonding clamp below this that feeds an earth to the other DB’s. The cast iron is not earthed to the lead sleeve. I have never seen one of these before in a property, my question; Is there a fuse in side this ? The cover had a seal on it and to be honest looking at the state of it I was not prepared to cut it off and look.
The client wants to upgrade the installation; at the moment he has two 8 way Wylex boards, A plastic 5 way board with MCB’s and a metal switch with 4 mini rewireable fuses within, this is so old it belongs in a museum. I can’t do any of the work as it is not possible to isolate the supply. There is no RCD protection on any circuits and all the sockets in the older part are wired as radials on 15A fuses.
I would like to get a modern service fuse installed by electricity board but want to know the correct term.
Any help would be appreciated. I will post some pics later, there must be some 80 year old electricians on the forum who have installed this equipment !
Regards Pat
Regards Pat
