1.An instruction to carry out work,whether written or verbal will be taken as acceptance of the terms andconditions detailed below.
2.An estimate is given as an approximate pricecalculated with all reasonable care by use of available and visible informationobtained at the time of the quotation, it will be given where an exact price isimpossible to give due to lack of information or inaccessible installations.
3.A quotation is an offer to complete the workspecified at the price given, any further work requested by the client will beaccepted via new quotation or an updated quotation as agreed by the client andCSES ltd.
4.All work carries a 5year Guaranteeagainst defective workmanship or installation materials. Electronic equipment,luminaires and all other accessories which carry a manufacturer’s warranty willbe subject to that warranty. CSES Ltd will accept no responsibility for defectsintroduced by tampering or alterations made to the electrical installationafter the completion of the works.
5.Prices do not include any chargesmade by the electricity supply authority (DNO) unless otherwise stated.
6.Variations to the quote, oradditional work required will be detailed by the client as soon as possible toenable an updated quotation/estimatetobe agreed upon by the client and CSES Ltd.
7.Emergentwork willbe agreed with between the client and CSES Ltd prior to work being carriedout. Should urgent work be required andthe client not available, CSES Ltd will endeavor to carry out the work usingthe safest and most cost effective solution to the client unless expresslyforbidden beforehand. This work will bechargeable to the the client. This may result in certaincircuits being isolated until a safe andcost effective solution be found to the problem.
8.All work will be carried out bysuitably qualified engineers and will comply with all relevant and currentBritish Standards alongside other applicable regulations.
9.All work will be ‘made good’ byCSES Ltd; this is limited to the reparation of plaster work, re-fitment offloor boarding and carpets but doesnot include redecoration.
10.All electrical materials andaccessories will remain the property of CSES Ltd until final payment isreceived.
11.Equipmentand accessories supplied by the client. CSES Ltd reserves the right to refuse to fit sub-standard, non-compliantaccessories or equipment supplied by the client. Quotes and estimates tenderedby the company arebased on the fitting of standard electrical accessories. Accessories that require excessivepreparation, modification or non standard fitment may incur extra cost to theclient.
12.Whilst undertaking testing worksand periodic inspections, it is the responsibility of the client to disconnectfrom the mains any sensitive equipment which will be damaged by high voltages,this may include computers, telephones, charging equipment and kitchenappliances. You must inform CSES if you suspect that any PIR outside lightingequipment may be connected to the socket ring main.
13.Billing. For work of an estimated protracted period ofmore than one month, CSES Ltd will invoice clients on a two weekly period formaterials and labour costs.
These are mine, Very much a work in progress........
