Tesch | on ElectriciansForums
Discuss Tesch in the Commercial Electrical Advice area at ElectriciansForums.net
marc8
Essex
hi all
very old oven has a Tesch timer unit installed, power works on unit but mechanism inside not working.
it is a set back timer with a full dial at rear & half dial in front. twist control round to 12 to open back timer which is the delay timer, then turn leaver back to hours you wish to cook for.
should i just set the front dial oven comes on no problem it is the timer that has stopped working internally.
need new unit or a replacement for the oven panel fitted 70 x 70mm hole. 230 volt inputs & outputs, but could convert if required but would have to install some relays, so if poss 230v.
or anyone know who or where to locate new unit?
A common panel mount size would be 72x72, check your cutout isn't this size, if it is you maybe in luck finding a suitable replacement.
Reply to Tesch in the Commercial Electrical Advice area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
