test board resistors | on ElectriciansForums
Discuss test board resistors in the Australia area at ElectriciansForums.net
T
tawraste
hi all,
anyone have any idea what resistors colleges put in test boards to simulate longer cables for decent ring test results?
cheers!
well. think of a longer ring circuit. work out the resistance of , say, 130m of 2.5mm, then that will be the value of the resistor plus whatever short bit of cable they use.
well, they ain't going to have to take much current when being tested. you're probably looking at 1/4 watt. you can get 1/2 watt and 1watt easily.
The training centre will be issued with instruction from C&G which will have the drawings including the resistors within. Not that I'm guaranteeing they'll all stick to the drawings.
Sent from my iPhone using Tapatalk
Reply to test board resistors in the Australia area at ElectriciansForums.net
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
