test form B | on ElectriciansForums
Discuss test form B in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
buddy
hi
A client has had a fire next door to her holiday cottage and the fire brigade have turned off her electricity and needs a form B to have it turned back on, which form is she talking about?
thanks
As with High Tower. "Dead tests" to confirm safe to power up then "live tests" to confirm installation is safe to use --- esentially a full EICR unless you've been doing some re-wiring in amongst it all!.
Each DNO/Fire Service seem to have different procedures for the same result so a chat to both should confirm exactly what format they want the EICR presenting in.
Reply to test form B in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You need some silicon oil spray
Okay I've changed it. Think I got away with that.
