Test Instruments and Equipment! | on ElectriciansForums
Discuss Test Instruments and Equipment! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
Edwardioo
What Test Instruments and Equipment will i need to do a function test on a electrical installation?
So far i have...
Volt Metre
Low Ohm Metre
Ins Resis Metre
RCD Tester
Impedance Tester
Screw Drivers
Side Cutters
Am i missing anything?
Cheers Ed
approved voltage tester. short lead with croc clips to link out when testing R1+R2 etc.
hi mate functional tests are usually by switching CBs on and off same with RCBOs and RCDs and switches and sockets and pressing the test button of the rcd to check the mechanical parts and are usually carried out once you completed all other tests
Reply to Test Instruments and Equipment! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
Mine is a Telequipment D75 from the 1970s. Still working spot on. Proper dual beam as well and very high EHT for really bright traces.
