Test Leads. | on ElectriciansForums
Discuss Test Leads. in the Electrical Tools and Products area at ElectriciansForums.net
Not used then Kewtech ersion but a set from maplins instead. I find its makes linking out easier than connector block or similar.
Also good as you can null out a socket adaptor easy with the too
Thanks Lenny,
Gonna order me some as well !!
Look very easy to use, as opposed to the old connector block routine !!
Sav
Senet held a brecfast morning and a kewteck rep was their ive ordered a full test set ,set of 5 light mate adaptors ,jump leads ,lock off ,and an r1r2 adaptor, all for ÂŁ65.00 just waiting to get it
Thought i'd get a set today as they look to have larger croc clips than the maplin versions, so might have a better contact.
PS.
Mr Test Meter you need to do something about your postage costs, got a set for 14.99 plus VAT including postage
my collage tutor used them(home made version)
at the time i had a fluke multitest which was random on continuity at best.
these just made it more random.
now ive a megger 1552 i may try it again...
after all some body always uses the last connector stip init!
Reply to Test Leads. in the Electrical Tools and Products area at ElectriciansForums.net
There is a lock on it, press the test button down and press the lock button, the symbol will appear on the screen in the middle right hand side...
I have a set. I must admit that I seldom use them however. But the concept is good in my opinion.
