Test leads | on ElectriciansForums
Discuss Test leads in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sivoodoo
Hi,
When putting the link between phase and CPC at the distribution board for R2 measurements and such other tests, what type of lead are people using, ive just used a piece of flex with croc clips.
Is there any such leads I could purchase that are a bit more substantial, what do you all use?
Cheers
Si.
Reply to Test leads in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
