interesting. might be worth a punt here:
Electrical Test Meters | eBay
Discuss test meters in the UK Electrical Forum area at ElectriciansForums.net
Hi Glenn,will that set up be solely for 30 Ma testing,and does any provision need to be made for the squirting of current down the cpc backside of the tranny? ....crikey,that went a bit "carry-on"...:38:
well think about what an isolating transformer is:
theres no reference earth on the secondry side....current will flow between 2 reference points yes....
so as the installation`s CPC ends at the incoming side of the transformer....and does not carry through...and of course you also have electrical seperation between the primary...and secondry windings....so there can be no reference between the starpoint & earth or neutral on secondry.
now, you need to create a reference for the test instrument to start injecting fault into from the phase (secondry)....so as theres no reference earth on the secondry side what you can do is create one by introducing a neutral-earth link....secondry side...
this will provide a path for simulated fault currents in mA...which will take out the RCD being tested....this would be any RCD connected secondry side.....and as theres no throughpath for leakage....the top end RCD will not see any leakage....caus it wont be there...will it.
Hope this explains things a bit.
Glenn.
At risk of sounding a bit green here . I like the idea where is it to be implemented ?
thats about the level of it.....Glenn
do you mean
" either get mugged off or make your own"
Reply to test meters in the UK Electrical Forum area at ElectriciansForums.net
