C
Colonel Hathi
Hi
I am knocking up a test rig for practice
The general set up is fine - but obviously limited in realism by short cable runs.
I would like to include resistors to simulate "real world" cable runs so that realistic readings are given on tests.
I really don't know much about resistors though
1. What type of resistor do I need to get to be able to handle 230volts?
2. Is it possible to get resistors that can handle 230 volts - below 1ohm?
I suppose I could use several resistors in parallel to get to readings down to reasonable levels?
Thanks in advance for your help
CH
CH
