Tester to find 'true' live | on ElectriciansForums
Discuss Tester to find 'true' live in the Electrical Tools and Products area at ElectriciansForums.net
Billio
Okehampton
Hello All
I looking for a (pen type?) of tester to find true live in a lighting circuit etc., any thoughts would be appreciated.
I believe they do exist but I cannot trace one (sorry of the pun)
Many thanks and enjoy the summer...
Billio
The pen type testers can't be used to prove a conductor is dead or live. They just give a rough indication, they should never be used to prove a circuit is safe to work on.
The site sponsor 'Test Meter' will be able to help you. And give you a discount.
Test Meter Discount Code
PS, and what Rob said.
You need the correct voltage tester for proving circuits live or dead, in the proper sequence.
a multimeter can find the switch line ( dead test ) and an approved voltage tester to determine which is feed in and which is out.
Reply to Tester to find 'true' live in the Electrical Tools and Products area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
