Testing 415V Extension Cables | on ElectriciansForums
Discuss Testing 415V Extension Cables in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
N
NKP1962
Hi all,
does anyone know if there is anyone who makes / supplies IEC cable assemblies for 32A 415V extension cables - if not - how can I test them on Europa Plus PAT Tester?
thanks in advance
For poly phase extension leads I use the "User defined" codes on the Supernova tester. I have to use a megger to test each conductor, putting pass or fail into results box on the tester.
Single phase leads are plugged into the tester and the earth continunity lead attached to extension leads CPC.
Reply to Testing 415V Extension Cables in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
out of interest UK, how do you know what kit is connected?
