Testing a db | on ElectriciansForums
Discuss Testing a db in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Robo
How much do you charge per circuit. 17th ed db. asked how much i charge per circ. ÂŁ20??
Reply to Testing a db in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
have you asked the manufacturer if they can provide you with a testing procedure?
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
