testing a domestic consumer unit | on ElectriciansForums
Discuss testing a domestic consumer unit in the Domestic Electrician Forum area at ElectriciansForums.net
R
redbarrett
i want to periodic test a consumer unit and would like to know what test sheet to use, i am an niceic domestic installer but the niceic wont let me buy the periodic test sheets until you are an approved periodic tester so what forms do you use.
im scared of women.
i also have the 2391 and am scared of the test sheets.
someone asking about testing here, and, actually trying to 'attempt' it is very silly in my eyes.
spose its just someone trying to help themselves and save a few quid.
now, i understand this, most people want to save money....but.......
there should be an 'electric-safe'...just like there is a 'gas-safe'.
part p my ar$e.
Reply to testing a domestic consumer unit in the Domestic Electrician Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
I have ascertained that I can have a fuse wire type consumer unit provided it passes the EICR tests and also that it can be in a waterproof...
Yep They try to sell, sell, sell At the last asessment I told the asessor that I used SELECT to update my regs and inspection and testing, on...
Sensible approach. When it comes to resell, you could get an indemnity policy, or get an EICR done. This will give an overall view of the...
