L
lofty84
I have my 2230 testing and inspecting practical tommorow and I just wondered if anyone can tell me if Im doing things right or wrong.
The first test we will have to do is the continuity on protective conductors
For this I will select the low ohm reading on the test instrument and null the leads. Then I will take out the main bonding conductor from the main earthing bar in the consumer unit and applly a crocidile clipped lead to the end of it then with the other lead I will take it to the main bonding clamp and take a reading and then to the pipe work and take a reading. I would then record the highest value.
Is that correct please
sorry forgot to add that i will be expecting a reading of 0.05 ohms or less
sounds right to me. but don't forget to null the leads with the wander lead connected ( if you are using a wander lead that is )
Your meter and sequence is correct. All you want for R2 is end to end reading of that bonding conductor!
BTW* Inspection & Testing, We inspect before we test!!
next I will need to check the continuity of the CPS, useing a choice of either method 1 (R1+R2) or method 2 (longlead)
method 1
for this I will need to make sure the leads are nulled and create a temporary link between the earth bar in the consumer unit and the line for each circuit I wish to test, I then make my way along the circuit testing between line and earth terminals at each point in the circuit recording the reading from the furthest point I think ? earth probe on first and then line.
although there is not a requirment for the R1 - Rn measurement I will repeat this but create a tempoary link beteen the earth bar and the neautral conductor for the circuit I wish to test and then test between the n and earth terminal at each point makeing a note of the reading gained at the furthest poin on the ciruit.
method 2
measures R2 (earth conductor) if they ask me to use this method instead of method 1 I would connect a long lead to the earth bar in the consumer unit and then with the other lead connect it to the earth terminal at the circuits furthest point.
I think .......
method 1
method 2
I think .......
Gn3 has it all in mate
method 1
method 2
I think .......
your method 1 would also confirm correct polarity. also, if it's a ring final circuit, you would cross connect the L and E 's at the CU and expect the readings to be the same at each outlet, except if there's a spur off the ring. again, you record the highest reading.
now haveing done the continuity of protective conductors and CPS ( i dont mean to sound stupid but I would take the R1+R2 reading for all the circuits on the board at the same time wouldnt I)
I will need to move on to continuity of ring final circuits I will need to test end to end on the following r1-r1, r2-r2 and rn-rn
to do this I use the low resitance ohm meter setting again and apply one crocidle clipped lead to the line going out to the ring and the other crocidile clipped lead to the line comeing back in (thats r1-r1)
I do the same again but this time on the neautral (rn-rn) and then finaly the cpc (r2-r2)
this will tell me if I have continuity on each conductor in the ring circuit
all values should be within 0.05 ohms of each other if the conductors are the smae size
next I have to connect the line and neautral conductors together so that the outgoing line in connected to the returning neautral and vice versa. I then take a socket adaptor and take reading between the line and neautral at each socket by putting the test probes into the holes on the socket adaptor. If i get a higher reading from one of these sockets it is going to be the spur.
I can then do the same again useign the earth (r2) instead of the rn
this test should also enable me to confirm polarity on the ring
and if you notice a continuos rise at outlets, theres something wrong.????
think you've got it spot on.
rem. on T/E the cpc is smaller csa, so on 2.5/1.5 your R2 will be 1.67 x R1.
Do not forget at the very first instance before you disconnect the Earthing conductor for the continuity of protective conductors, that it needs to be locked off, and proven to be isolated.
method 1
method 2
I think .......
With regard to R1&RN it's between Line and Neutral, not Neutral and Earth.
With regard to the method 2 test, be sure to null out any wonder lead they give you. Or measure it's resistance separately and deduct its value.
right next up then will be the insulation resistance test.
haveing made sure any sensitive equiptment is dissconected I would select the 500 V dc option (do I remove the main earthing terminal as to get rid of any paralell paths ?)
I will need to attach one crocidile clipped lead to the line conductor and the other to neautral conductor and press test on the megger I should expect a reading of >299 M ohms on the tester I will be useing
next I test between the line conductor and the main ear bar in the consumer unit again expecting a reading of >299 M ohms and then finally between the neautral and main earth bar in the consumer unit again looking for a >299 M ohm reading.
if the reading is less then 2 M ohms i will need to investigate as to why this is although the regs state that the minimum allowable reading for insulation resistance is 1 M ohm
sound advice there from the wookie. LOL.
Remember also to carry out FUNCTIONAL CHECKS when doing R1&R2 tests. A good habbit to have is to switch every socket and switch off when you initially approach the rig, so you can be reminded to carry out a functional by default when you are forced to operate the switching to obtain a value.
Remember to put all switches in the closed position (on) and if there are any two way switching then the tests to line will need to be done twice, with the operation of a switch in-between to include BOTH of the strappers under the test.
ok next I think is checking that the polarity of circuits is correct which i think I would have done useing method 1 when checking the contiunity of protective conductors and continuity of ring final circuits
I will still need to confirm that the breaker and switch are on the line conductor, how do I do this
is it
to test the polarit of the supply
for this I will want to test between the distributors incomeing line and neautral conductors looking for a 230V reading
and then between the Line and Earth looking again for 230v
finally the Neautral and earth but this time I should get a reading of 0 volts if the poalrity of the supply is correct
i dont know how many tests in I am at this point but next I think is the external earth fault loop impedane test Ze
for this I deffo need to disconect the main earthing conductor as we dont want any paralel paths. I take my megger and select the external earth fault loop impedance setting and attach one crocidille clipped lead to the main earthing condutor that I removed from the main earth bar in the consumer unit and then with the other lead put the probe on the incomeing line conductor.
depending on the earthing system I have i should expect reading that are lower then the following for each earthign sytem
tncs <0.35 ohms tns ,o.80 ohms tt < 200 ohms
fingers crossed thats right
is it
Dead Polarity -
Verified by method 1 excluding socket outlets, however R1&RN will confirm polarity. So R1&RN will be a MUST for rings & radials.
Confirm switching in the Line conductor only can be partially verified by method 1, but in the case of double pole isolators and motors, functional checks will also contribute.
Also consider the switching of multi pole devices, shower fan isolators etc.
Plus the centre contact of an ES lampholder must be connected to the Line conductor.
Live Polarity -
Is as you've described, but be sure to apply the indicator to the Line last, and remove it from the Line first. - 'Line on last, Line off first' - Try to remind yourself of that.
If you carry out test between the Earth and Neutral last, then recheck the detector by re-applying it to Line to verify it' working (proving on a known live supply).
That's fairly spot on. Nice to hear someone using two lead meggers in training now.
If you had to remove the lock off to remove the cover, be sure to replace it before removing the Earthing conductor.
You may measure a higher value than anticipated, this would depend on weather the test rig is close to the origin or downstream plugged into a final circuit of some kind. If the latter is the case then be aware that it's not the true Ze you are measuring.
The college may provide you with a more accurate Ze value if this is the case.
after the pefc test it time to move on to the live tests which are the earth fault loop impedance test which is simply a case of selecting the no trip setting and plugging the tester into all sockets takeing the highest reading i think ???
finaly its the rcd tests where i need to test 1/2 1 and 5 x I delta n at both o and 180 degrees.
i hope i can remeber all this as all ive got left is these two practicals
just flick the switch on your megger after your performing Ze test but have bonding conductor connected for this....
so basically after dong the ZE test reconnect the main earthing condutor and select the pefc setting on the megger hit test and it will tell me the result ..
Remember
Prospective fault current is the highest value of the results of
Prospective short circuit current and
Prospective earth fault current
and that value should be recorded on the test results
don't forget to test with test button as well
Testing and Inspecting
lofty84,
telectrix,
