Hello,
Couple of questions, firstly does each flat require it's own dedicated earth to the main incoming on the ground floor of the property, zs readings are fine with the 10mm 3 core SWA that has been used. (never certed a block of flats before, jus wanted to be 100%)
And, there is a heater in the bathroom that only has it's own pullcord isolator, does this require an FCU outside of the zones?
Thanks in advance
Thanks in advance
