Testing breakers | on ElectriciansForums
Discuss Testing breakers in the UK Electrical Forum area at ElectriciansForums.net
E
Eddiesparks
Interesting that we dont test mcb's like we do rcd's. To see if they trip as according to their time/current curves. I'm guessing the practicalities of the test gear is why? Anyone else got any suggestions?!
This topic has been discussed before, I'm sure a search will reveal lots of info.
But the basic problem is that to test it properly will make it unsuitable for continued use.
Manufacturers test samples from each batch, these samples are then thrown away after testing as they will be damaged by the test process.
Interesting. Amazing they are not all tested. There must be a few out there then (esp b&q ÂŁ50 CU s) that wouldnt trip at the right time/ current surely?!
I know they are manufactured to a BS number but so are rcd's and we still test them.
Surely a variable resistor that you can stick across L and N would do the trick with a nice tasty BANG!! :)
You would only destroy/damage them if you passed a current equal or more than their rated KA breaking capacity. The main or overwhelming reason why they are not called on to be tested after installation, is the cost of the test kit that would be needed to test MCB's, eg, ''A Primary current injection'' test set... Were talking several 1000 pounds. MCB's are actually generally very reliable and a proven means of protection, far, far more reliable than RCD devices....
We test all our MCCB/ACB/GCB's etc on our main Distribution/Switchboards using Primary and Secondary injection testers, so we have the means to test any of our MCB's if they are/become suspect, but don't test them as a matter of course....
Reply to Testing breakers in the UK Electrical Forum area at ElectriciansForums.net
It can also mean lasts or continues for two years.
has anybody tested the coffee machine for safety? I would try putting a normal load on the same supply as the monitor and see if that goes off at...
