dean1802
Hi,
Im currently installing a coax satellite system using MK Quadplexes and want to carryout a simple continuity check on the cable prior to the walls be closed up, can I do this using a wire mapper with the coax terminated into the quadplexes or do I need to do it prior to terminating in the quadplexes, I am a little concerned that the quadplexes's 'electronics' will cause issues.
