Testing commercial property | on ElectriciansForums
Discuss Testing commercial property in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stidge
Nottingham
Hi all some advice please,
Have been offered a job at an old aerodrome,its to be a skate park with cafe and toilets.I am only an NICEIC Dom Inst,Can i still carry out works on 3 PH CU and test and certify myself on NON NICEIC Certificates???????????
yes, if you are competent to do so. 2391 would however be an advantage , as would professional liability insurance.
As long as you feel competant and they are not asking for NIC certs in particular then why not.
The green NIC forms are available for anyone to use.
Reply to Testing commercial property in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
