doglog
Hello, can anyone give me some help on testing. I need to do an Insulation Resistance test on a lighting circuit with 24 ELV downlighters on it with individual transformers. I can do the live/earth and neutral/earth by testing live and neutral together to earth but the live/neutral test always gives a reading (obviously) even with the lamps removed (again obviously). I know if there was a live/neutral fault the breaker wouldnt set but is there some way to carry out this live/neutral test without disconnecting all the transformers.
Thanks for your help
Paul
Paul
