I am having trouble testing an installation with several Fike Twinflex Multipoint detectors set to heat mode. I have a Solo 460 heat tester which works fine with Apollo A1R detectors but not with the Fike detectors. I think the reason may be that the shape is different - it looks as if the hot air is blown out of the tester head at the wrong height for the Fike detector. Is it possible to fit a different shape hood to the tester head to compensate?
Anyone else encountered this problem?
