Testing floods with P.I.R's | on ElectriciansForums
Discuss Testing floods with P.I.R's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
revolt3k
When testing IR on a circuit spplying some outside floods with built in pir's, Is there any other way other than disconnecting the p.i.r in the fitting's?
yeah i can isolate via a 20A isolator but i need to test the circuit feeding the lights. Not to worry i will have to disconnect the light fittings and place a connector on them or just disconnect the feed to the fitting in the terminal block in the fittings themselves for the IR test. Just wondered if there was another way. Might need to do this on my assessment thats all.
thanks
Reply to Testing floods with P.I.R's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
