- Joined
- Jan 7, 2011
- Messages
- 50
- Reaction score
- 5
hello all,
i just installed a new cu, which some of you may have read in another one fo my threads. everything was fine until i tried to connect one of the ligthing circuits to the board but it made the RCD trip every time.
i did some reading and suspected the ole borrowed neutral dilema.
Now i just want to run something by you so bare with me.
Imagine the new cu is installed
all circuits connected (except light circuit) and working fine
connect earth to earth bar of light circuit and all ok
connect nuetral to neutral bar and pop goes one of the RCDs
connect nuetral to the other neuitral bar and pop goes the other RCD
connect L1 to mcb and pop goes RCD
connect L1 to another mcb on other RCD and that pops too.
does this sound like borrowed neutral.
I tried to connect linked circuits into one mcb and but its RCD still tripped.
So i am thinking perhaps this is not a borrowed earth but perhpas insulation reistance problem. However the mcb never trips so if there is leakage of current it is too small to trip mcb but big enough to trip rcd.
can any one suggest a test method to either prove or dicprove this.
thanks very much
DD368
thanks very much
DD368
