A
A-Non-eMouse
hello chaps
i'm going to be doing some final live tests in a block of flats were doing at the mo on monday and was trying to remember what earth cable to test on for Ze in the flats consumer unit. The flats are fed by a 16mm t+e submain with an additional 16mm earth run along with it. now do i test for Ze using the t+e earth, for a worst case scenario, or the other 16mm earth. whats the correct procedure here?
also i didnt run the submains in but as i said earlier they are 16mm t+e plus additional 16mm earth. now as the run is over 3m am i right in saying that they have to be fed through a fused isolator as there not mechanically protected ie there not swa submains as currently they just come from the meter through a 63a double pole isolator and off to each flat.
thanks for your imput in advance
