Hello sparks,
I'm looking for some advice as to see how I can wire up and test hand dryers prior to purchase. As they're generally unwired, without a plug connected. I have some basic electric screwdrivers from TLC as well as an electric tester and some basic strip pliers from TLC. I'm familiar with tools just not the electrical side of it. I also have a plug with a cable attached with has a two way cable connector box attached to it. How should I go about safely and correctly testing the hand dryers. Not to fully wire, just enough to test safely. They are dyson hand dryers,
Kind regards.
Pirate's idea is probably the best. Saves putting a plug on before you test (ISITEE) them.
If the real question is how to test for electrical safety then it is more complicated (and expensive).
If you only have a couple to check then paying someone to do the testing for you would make the most sense.
However, if you have a business that will need this done repeatedly for the forseeable future then you can buy one of the largely automated testers (something like the "Seaward Primetest 50 Kit" for a bit under £300) and go on a short course to learn how to do the basic testing.
But AFAIK typical Dyson hand dryers do not have a captive cable, therefore the Quicktest / Safeblock connector is of no use as a flex needs to be connected to the dryer for test. In which case the temporary flex might as well have a plug on the other end rather than going via the quicktest. Good practice would be to put a plug lockout on the plug at all times other than when the dryer is under test, to avoid accidtentally making the bare ends of the uninstalled flex live.
Very good point.
Alright. I have a connector box attached to an existing cable/plug. Though the dysons I plan on checking have no protruding cable so I'd have to open the hand dryer up. Is it generally a three core connection that's accessible to attach to it when opening it up to connect.
Depends if they are class II (double insulated) or not. Do they have the double square symbol?
There are quite a few places that do PAT testing (or ISITEE to give it is correct title these days) at fairly reasonable prices, far cheaper than you could do yourself unless you plan on doing a lot per year. If you have a batch of a few to be tested it would be cheaper as a lot.
You probably could and should do a basic "does it seem to work?" test first to rule out ones that are not functional, but the cost of a tester, course, and insurance to cover your posterior for anything that might go wrong, makes it not worth doing yourself unless you are doing, say, a hundred per year or more.
Of course, if you do have need for many items or other electrical stuff being tested then you might find it cheaper to go on a 1-2 day course, buy a tester and get basic insurance for it.
Very good advice there @pc1966
I may have misunderstood the op initially, as I thought the dryers came with a cable connected, but no plug.
I use that connector block for ISITEE, and have a cable and 13A plug connected, with an extension lead terminated with Wagos to allow testing of hard-wired heaters etc. Thus, it can provide mains voltage to items to run them, or plugged into a PAT machine for ISITEE testing.
It's versatile , but you need to work correctly...
I agree that it may be better to farm-out the testing, or do a proper course, buy a tester, and learn how and why.
england
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
Testing Hand dryers prior to purchase
Electrical Appliances & Whitegoods Forum
aceofspades,
pirate,
