testing heating | on ElectriciansForums
Discuss testing heating in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sparky_Ben
What dead tests are required on a central heating system? this is a system which i have never come across or carried out.
thanks.
also this might seem a stupid question but how am i suppose to check polarity on the valves when they are hard wired to the wiring centre?
go easy if this is a stupid question
In the first instance it's the circuit's polarity you are checking and testing (up to the FCU supplying the boiler). Then by inspection/testing the valves etc as attached in the wiring center (assuming there is valve/wiring center). You will occasionally find yourself in the position of just installing the FCU and Room Stat and the plumber will wire the rest (but not that often).
right okay, but if everything is wired to the centre there isnt a great deal left to test other than stripping down all the pumps etc.
OK, let me play devil's advocate. What would you want to satisfy yourself of before you energise the circuit (assume that a plumber had connected the wiring centre etc). What could be damaged if the circuit was energised and the centre was wired incorrectly? Assume your checks had confirmed a 3A fuse in the FCU supplying the boiler.
Sooo, you can test up to the FCU using standard methods (per the book). Without having any voltage at the wiring centre you can still do a fair bit of continuity checking from the wiring centre to the valves etc to satisfy yourself it's wired as it should be (or not). Same for the room stat.
thanks for all you advise, i am confident now that i will be able to test the circtuit as much as possible, prior to energising, much appreciated
Get a printed copy of the standard wiring diagrams (from the Central Heating Forum stickies). That'll give you some pointers on how they are often wired (but don't expect everyone to follow them rigidly).
is this a final circuit? surley that stops at the fused spur or socket outlet that supplies the control wiring. i dont think it would be part of the test cert. i would check the earth conection at various points of the system and the fuse rating probally the condition of wiring but that would be it.
Reply to testing heating in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
H
Central heating system cleaning Hi all, I have added a bottle of Fernox F3 into my towel radiator upstairs, I have run the heating for a good few...
Happyharry
H
This is an RSS feed of thread: What are the best heating flushing systems Content of the thread: Any advice on selecting the best central heating...
