Testing IR with serge protection | on ElectriciansForums
Discuss Testing IR with serge protection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jamminuk
Hi,
Just wondering how you would test IR when there is serge protection in the installation? Would it be a case of linking it out or reducing the test voltage?
Also why would a test for Zs trip RCD? :banghead:
Thanks again in advance
Ben
Hi,
Ben
You can test at 250V dc but the result must still be greater than 1MOhm.
The voltage is reduced to prevent the SPD from leaking to earth (as it should) at higher voltages.
As for the Zs test, think about the current that the tester is applying between L and E on an earth loop impedance test. ;)
Between which conductors?
Thanks.
Generally, you'd be able to test between all conductors at 250V dc but you'd still be subjected to the same constraints from other sensitive devices (ballasts etc.) that might mean you'd be testing with L+N combined to Earth.
Reply to Testing IR with serge protection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
