Testing led downlights | on ElectriciansForums
Discuss Testing led downlights in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
gafc156
Just wondered if anybody could give me some advice please, i have eleccsa assesment this week and wondered what the best procedure is for insulation test on led lights.
would the inspector prefer to see all lamps removed (14) or is it better not to disturb the lamps and test at 250v instead.
thanks
Is it a new build or a existing installation?
If it a existing installation, you could just test the lives cables to earth and Lim the other boxes for installation testing. The other option is to remove a lamps from the circuit.
Cheers think i`l go with LN-E test to be on the safe side, hopefully he will pick another circuit for me to do IR test on
If he does ask you to carry out the test on the LED circuit just explain what you are doing and why, he will probably be more impressed that you thought about it than spent time removing all lamps from the circuit.
Reply to Testing led downlights in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
