C
ColinJ
Hi guys (and gals), this is my first time on the forum, I am hoping one of you can put me straight.
I have been an electrician since I left school in 1975, I am on the NICEIC list as a domestic installer.
I have just finished some new circuits in a detached garage that has been converted for office use. The supply to the garage is from the house consumer unit via a 40amp mcb, rcd protected. The supply cable is a 10mm swa with a separate 10mm earth conductor.
There is a 4 way cu in the garage with 100 amp isolator and I have installed a new ring main and a new lighting circuit to this board.
My question is, when I do my testing and certification, do I have to do a complete test on the house electrics or just the garage cu with my new circuits? I am assuming that I would need to do my Ze and pfc tests on the house board in any case.
I think I have to test the whole house for the certificate, but I just wanted to check, as it's a lot of work.
Any advice would be great ta.
