Shock Doctor
Hi all,
I am changing over a consumer unit in an old flat, the feed to the block has just been renewed by EDF ( 6 months after I informed them of no earthing to building! ) The lighting circuit has no cpc, so I downloaded the guide to changing a CU with no cpc from the electrial safety council and followed it to the letter. My problem comes with the continuity test for the lighting circuit, as I have no cpc to test R1+R2 can I test between R1+RN at the light fittings to prove continuity as all connections are hidden in the ceiling and the switch drops T off the circuit in the ceiling also.
Any answers or advice gratefully received.
Many thanks.
Many thanks.
