TESTING R1 + R2 garage supply | on ElectriciansForums
Discuss TESTING R1 + R2 garage supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
iceman
hello im tryin to get ready for me assesment with the nic iv got a ring final circuit upstairs witch provides power to the central heating off a fuse spur when testin R1 + R2 do i test all sockets and the spur or just the sockets? thanks
also theres a garage supply comin frm a 20A circuit breaker frm the house providing power via a fuse spur 2 socket outlets and 3 light points when testing R1 + R2 do i test every point including the spur? thanks
yes the sockets are on a radial circuit when i practicing i went straight to the furthest point but on the day the asseser will probley want to see me test every point :-/ lol
Just out of interest, why would he want to see the test at every point?
Edit. Duuuhhh. Just realised what i said.:D:D
Sorry, i've been out in the fresh air all day.
why would you take a R1 + R2 on a radia (R1 + R2 only on a ring)l and how can you take a R1 + R2 reading on you central heating surly it would just be a R2?
One point to bear in mind is that if measuring on the load side of a fcu the acceptable value will depend on the rating of its associated fuse and not the circuit protective device at the consumer unit.
spark1
Because you are measuring the possible fault path of that circuit to see if it is within the limits required
sorry i thought you only nedd to take a R1 + R2 reading on a ring, just new to testing tho.
Reply to TESTING R1 + R2 garage supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
